TwinTurbo.NET: Nissan 300ZX forum - Re: Used vacuum diagram from Nick 2009 Stradsport....
Subject Re: Used vacuum diagram from Nick 2009 Stradsport....
Posted by ThunderZ on January 03, 2016 at 7:45 AM
  This message has been viewed 361 times.
In Reply To Used vacuum diagram from Nick 2009 Stradsport.... posted by 91z tt on January 02, 2016 at 10:54 PM
Message I would check if the timing belt jumped a tooth and if so, see if the tensioner is still set to spec.
For the vac/air tests, did you use a boost leak tester? That revealed leaks for me I thought didn't exist.
How did the power balance test come out?
Looks like you already swapped in known good parts for MAS, TPU, CAS, FPC.
Last thing - you said voltages are all over the place. Did you check if your alternator is still OK? That can cause big problems.
G/L.
