TwinTurbo.NET: Nissan 300ZX forum - Re: Code 71 and ignition timing
Subject Re: Code 71 and ignition timing
Posted by Metacom on December 28, 2015 at 11:09 PM
  This message has been viewed 589 times.
In Reply To Code 71 and ignition timing posted by Metacom on December 23, 2015 at 08:17 PM
Message Testing the PTU today and came across some conflicting info in the 96FSM vs. 95 and earlier FSMs.
[ http://i.imgur.com/Cmb3Gdy.jpg ]
96FSM (top book) Terminal G which it labels as I4 when tested in the position of:
G (Terminal 3 in the 95 and earlier FSMs) (-)
E1-6 (+)
96FSM says there should be continuity. My PTU did not have continuity. Testing in continuity mode or for OHMs. So that would be a Fail.
The 95 and earlier FSMs (bottom book) says testing in that position it should be open/no continuity. Which there is none as mentioned above...so that would be a Pass.
Same thing for the I6 through E6 continuity tests vs terminals 1 and 2 combination in 95 and earlier FSMs.
Terminal combos G and I1-6 (96FSM) vs Terminals 3 and 2 (95 and earlier FSMs) is a pass on both interpretations.
Since the Z runs and accelerates fine outside of idle I'm inclined to believe the interpretations following the earlier versions.
