TwinTurbo.NET: Nissan 300ZX forum - It's not always easy to see that the clutch is going.
Subject It's not always easy to see that the clutch is going.
Posted by zellamay on December 28, 2015 at 1:48 PM
  This message has been viewed 357 times.
In Reply To Re: First thing is to make absolutely sure it's adjusted posted by freddo on December 28, 2015 at 10:59 AM
Message It can start slipping because the disc is worn out. It can also start slipping because the pressure plate pressure is weakening, which can't be seen. I had a JWT clutch wear out prematurely. First, I'd say to figure out whether the clutch is adjusted properly. If it is, just take it apart. If it is not, then show them it is not, point out that it is slipping now, and state that they are responsible for the clutch wearing out prematurely. They may or may not take responsibility.
