TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Cracked plastic engine fan?
Subject Re: Re: Re: Cracked plastic engine fan?
Posted by ttz'in (norcal) on December 27, 2015 at 11:26 PM
  This message has been viewed 433 times.
In Reply To Re: Re: Cracked plastic engine fan? posted by burntclutch on December 27, 2015 at 08:24 PM
Message Covered by the shroud, but removal is EZ with shroud in place.
Four 10mm nuts attach it to the water pump flange studs.
Release belt tension if necessary to keep pulley flush with water pump flange on install.
