TwinTurbo.NET: Nissan 300ZX forum - Left Bank Rich, Right bank Lean at Idle
Subject Left Bank Rich, Right bank Lean at Idle
Posted by Cjw3 on December 23, 2015 at 9:15 PM
  This message has been viewed 661 times.
In Reply To Code 71 and ignition timing posted by Metacom on December 23, 2015 at 08:17 PM
Message Left bank O2 sensor at idle is reading high while the right bank is low. There is your problem..
That would indicate a T-Body balance problem.. Or some other Non Balanced air leak ( PCV or Vac line Off ) That is likely where your Stumble is coming from..
I have not messes with a Running '96 before, so I'm not any real help on the Procedure for T-Body or Idle adjustment.. But check the PCV's and hoses.. Fuel Regulator Vac Hoses, and see if you can locate a leak..
Cj
