TwinTurbo.NET: Nissan 300ZX forum - Re: Looking to clean up my electrical mess.
Subject Re: Looking to clean up my electrical mess.
Posted by Svt_troy on December 19, 2015 at 7:50 PM
  This message has been viewed 435 times.
In Reply To Looking to clean up my electrical mess. posted by YlwPrlZTT on December 19, 2015 at 06:36 PM
Message wiring is a pita. You need to label all the wires you want to clean up and then determine the best route to clean them up.
If you want more than just zip tieing the wires neatly you can use wire loom or braided sleeving like this: https://www.wirecare.com/braided-sleeving.asp
Its expensive at that site so shop around, you can get it off ebay in different sizes for alot cheaper. The link is just to show you if you are not familiar with braided sleeving.
A distro block being worth it depends on how many aftermarket 12v wires you currently have ran and if there all battery 12V or switched. I only like to run distro blocks for 12V battery with one larger gauge wire ran from the battery to the distro block.
There are plenty of options to clean up wiring, some better than others. Just take your time, label everything and determine whats best.
Good luck
Follow my build here:
http://www.300zxclub.com/showthread.php?t=226455
