TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel System
Subject Re: Fuel System
Posted by Svt_troy on December 18, 2015 at 4:31 AM
  This message has been viewed 362 times.
In Reply To Fuel System posted by TurboTurtle (WaldorfMD) on December 13, 2015 at 08:36 PM
Message What's the amp draw on the pumps your using? Are you using the OEM wires to power the pumps?
It's known that the OEM power wires are not adequate in supplying power to higher amp aftermarket pumps.
For example I am running two Walbro 485's. I ran a 10AWG power wire from the battery to my relays. The relay output power wire to pump is 12 gauge. The ground wire needs to be the same gauge as the power
Follow my build here:
http://www.300zxclub.com/showthread.php?t=226455
