TwinTurbo.NET: Nissan 300ZX forum - Re: Ign Coil Relay is pulled to ground by the ECU
Subject Re: Ign Coil Relay is pulled to ground by the ECU
Posted by fleshworkstt on December 08, 2015 at 10:51 PM
  This message has been viewed 556 times.
In Reply To Ign Coil Relay is pulled to ground by the ECU posted by Cjw3 on December 08, 2015 at 10:19 PM
Message Thank you for your help. Iv searched and found one guy with the same issue im having he ended up with a bad ground on or at yhe ecu. My set up is jwt ecu fed addition my cars auto will the ecu from my 5 sp work on my auto even if its just to start it? Iv read that the auto can be used in the 5sp ( my 93 is apart for a boared long block build) but 5sp wont work for autos. One more questio Cj am I testing for a ground pulse at the mentioned wire at the ecu? Or would it just show ground with the ignition on?
http://images.craigslist.org/00G0G_gDUo8FF4dgA_600x450.jpg
