TwinTurbo.NET: Nissan 300ZX forum - recirculation valve question?
Subject recirculation valve question?
Posted by fleshworkstt on December 07, 2015 at 4:00 PM
  This message has been viewed 349 times.
Message Short history car had many issues.Most where due to poor work most of the plugs to my fuse block where loose.So yeah took me a min to find that issue. Now the car is running all works but Speedo is maxed out.My issue is the car is surging with any throttle at all. So I checked my recirculation valves the pass one makes a noies when I apply vacume to the valve at the top vacume nipple. I removed it it has a very small what seems to be factory hole in it. Is this hole supposed to bleed air when the car is off and under vacume? The pass side has a little hole in it as well but dose not leak air under vacume. Any help would be greatly appreciated.
So when I apply vacume to the pass reicr valve it leaks air is this Rt or is it bad/ stuck blown?
http://images.craigslist.org/00G0G_gDUo8FF4dgA_600x450.jpg
