TwinTurbo.NET: Nissan 300ZX forum - Re: Do a vacuum test and observe the needle, lots of >>.
Subject Re: Do a vacuum test and observe the needle, lots of >>.
Posted by Dsouthz32 on December 02, 2015 at 12:02 AM
  This message has been viewed 301 times.
In Reply To Do a vacuum test and observe the needle, lots of >>. posted by ZUL8TR on November 28, 2015 at 04:04 AM
Message No build up of oil on exhaust pipes.
No oil in coolant.
Did vacuum test and it was at 14-15in/hg with the needle fluctuating rapidly.
Compression numbers on 1(120 psi)3(120)psi. I did not do a wet test because I knew I need a rebuild from the tests. There was oil on cylinder 1 and 6.
Thanks for the guidance.
