TwinTurbo.NET: Nissan 300ZX forum - Confirming Correct Oil Feed Line Banjo Bolts
Subject Confirming Correct Oil Feed Line Banjo Bolts
Posted by zQuikonE on November 30, 2015 at 2:12 AM
  This message has been viewed 1284 times.
Message I ordered new oil lines and banjo bolts but what I have on hand is different than what came off the JDM engine from my front clip on just the driver's side. Can anyone help me take a look and double check things?
Driver's Side
The new bolt pictured on the right, PN# 16432-V530A, is what I believe to be the correct one for the driver's side and has a letter "B" on the head. However, it looks to be restricted when I compare it to the bolt on the left which was originally on the engine connecting the oil line to the block. Should I just use the original bolt?
I also found that the bolt on the engine used 2 crush washers but from what I read on here, a single joined crush washer is supposed to be used here. Another JDM or earlier year difference?
Passenger's Side
I did the passenger side first and used the K bolt which looks restricted inside and actually is a direct match with the original bolt on the engine.
K bolt installed on passenger side
Any info is appreciated. Thanks!
