TwinTurbo.NET: Nissan 300ZX forum - Re: Re: **UPDATE** Alternator Tested fine
Subject Re: Re: **UPDATE** Alternator Tested fine
Posted by Edgecrusher on November 27, 2015 at 1:28 PM
  This message has been viewed 239 times.
In Reply To Re: **UPDATE** Alternator Tested fine posted by Edgecrusher on November 27, 2015 at 11:33 AM
Message ::Just went to return what I thought was a dead alternator, turns out the alternator tested out fine, so I have no clue as to why the car isn't getting any power at all from the alternator, what else could it be? Fuses? Defective wiring? I'm at a loss as to where to start here.
:Just checked the fuses, nothing is blown, so it's not a fuse issue.
Just checked the alternator clip at idle and while the car is not running, getting 12 volts at idle, and 13 volts while the engine is turned off, I attribute the one extra volt to the battery being connected to jumper cables when I tested power coming off the battery with the engine being turned off.
