TwinTurbo.NET: Nissan 300ZX forum - I would check the voltage at the battery when it is running
Subject I would check the voltage at the battery when it is running
Posted by SammybTT(TN) on November 22, 2015 at 8:54 PM
  This message has been viewed 288 times.
In Reply To Replaced alternator, car starts but will not stay running posted by Edgecrusher on November 22, 2015 at 03:28 PM
Message If the alternator isn't operating properly the voltage should be around 12 Volts if the battery is good. If the alternator is functioning properly and the wiring is correct you should read approximately 14 volts. Hope this helps. Was the alternator new, used, OEM?
