TwinTurbo.NET: Nissan 300ZX forum - Re: The Pistons are 3.419?
Subject Re: The Pistons are 3.419?
Posted by Tech@EPR on November 20, 2015 at 7:30 PM
  This message has been viewed 430 times.
In Reply To The Pistons are 3.419? posted by Cjw3 on November 20, 2015 at 04:29 PM
Message no the correct way of doing it is spec the piston based on its cam profile. From there they "suggest" what the minimal clearance it should be ran in based on bore dimension with clearance included. For engines running higher boost pressure and seeing higher than normal temps and pressures you want to compensate for that with an added amount of P to W clearance.
