TwinTurbo.NET: Nissan 300ZX forum - The Pistons are 3.419?
Subject The Pistons are 3.419?
Posted by Cjw3 on November 20, 2015 at 4:29 PM
  This message has been viewed 324 times.
In Reply To Re: How big are 87MM Wiseco TT Pistons? posted by Tech@EPR on November 20, 2015 at 03:31 PM
Message I've always known it to be the BORE was the 'Nominal Dimension'.
Then in the Mfg Process of the Piston, the INITIAL Factory Spec. P/W Clearance was machined in the Piston Diameter..
Then the entire thing was measured and bored to what you wanted any way so Nothing was ever AT Nominal Dimension..
Cj
