TwinTurbo.NET: Nissan 300ZX forum - thanks for posting the actual problem
SammybTT(TN)
on November 12, 2015 at 7:25 PM
Update:problem solved
posted by L£AÐZX
on November 12, 2015 at 05:39 PM
From the way I read your post I wouldn't think the line would hold all of that fluid and I thought you said you checked the line and slave cylinder. Anyway main point is you located the issue. Good job!
Sporadic clutch feel
L£AÐZX
02:11:52 11/11/15
Forgot to mention the pedal stiffness comes back after a min (n/m)
L£AÐZX
02:13:49 11/11/15
Quick update
L£AÐZX
04:28:03 11/11/15
My "guess" is, your booster is failing and
ZTicket(Dallas)
07:44:47 11/11/15
Pull off the clutch master and see if fluid is >>>>>>>
ZUL8TR
08:06:14 11/11/15
Still stumped
L£AÐZX
10:12:03 11/11/15
can't violate the conservation of mass law it is going >>
ZUL8TR
13:38:30 11/11/15
Agree with Pete. First my slave cylinder need went out
SammybTT(TN)
19:51:43 11/11/15
New clutch M/C (n/m)
ttz'in (norcal)
15:47:51 11/11/15
L£AÐZX
17:39:56 11/12/15
That's what you get when you buy from a company the uses
itsa300zx
18:44:40 11/12/15
I have one from Z1 for the last several years without issue (n/m)
SammybTT(TN)
19:22:16 11/12/15
thanks for posting the actual problem -
SammybTT(TN)
19:25:59 11/12/15
To the above
L£AÐZX
00:52:10 11/13/15
That was a devious little sneaky bugger. Great that you >>
ZUL8TR
03:24:09 11/16/15
