TwinTurbo.NET: Nissan 300ZX forum - Pull off the clutch master and see if fluid is >>>>>>>
Subject Pull off the clutch master and see if fluid is >>>>>>>
Posted by ZUL8TR on November 11, 2015 at 8:06 AM
  This message has been viewed 397 times.
In Reply To Sporadic clutch feel posted by L£AÐZX on November 11, 2015 at 02:11 AM
Message leaking out the back seal in the clutch master. That's is the most likely culprit if you see no leaks at the slave or the plumbing from the slave to the master. Have you pulled the rug away at the clutch pedal area and looked behind it for fluid saturating the underlay material? You would probably smell it by now of inside the car.
ZUL8TR in Orlando,FL
