TwinTurbo.NET: Nissan 300ZX forum - 14RPM is the drop measured when that cylinder is deactivated
Subject 14RPM is the drop measured when that cylinder is deactivated
Posted by ttsmokin on November 09, 2015 at 6:39 PM
  This message has been viewed 314 times.
In Reply To dealer said "14 RPMs" or 14 ohms? posted by SammybTT(TN) on November 09, 2015 at 05:11 PM
Message Compared to the 85 to 200RPM drop seen on the other cylinders.
I would do a compression test and if possible a leak down test if the compression results are poor.
Don't adjust the throttle cable to try to solve an idle issue. There needs to be some slack in the cable, put this back to the way it was.
What injectors did you replace with, did you use new o-rings and lube them before putting the injectors in?
