TwinTurbo.NET: Nissan 300ZX forum - Drivers high beam, stuck on. Vehicle off
Subject Drivers high beam, stuck on. Vehicle off
Posted by BannonZ on November 05, 2015 at 7:59 PM
  This message has been viewed 282 times.
Message Hey guys. Funny enough, I fixed a throttle issue I've been having for two years this afternoon. It was a simple adjustment nothing electrical. I started the vehicle and let it run for two or three minutes before leaving work. Got in, serious electrical burning smell. No dash lights and both high beams on. Has happened before (as far as the fuse blowing, not the smell) and I've had to change the lamp/acc fuse on the inside fuse panel. Changed the fuse when I got home and it immediately popped and shorted. When I turned the headlights off to resolve tomorrow the driver's high beam remained on, no key in car and switch actively turning passenger side off. So, two problems. Drivers h beam light staying on unless I disconnect the batt or the drivers headlight relay. Tried to put the pass side relay on the driver's side and it was still on. Any ideas of where to start?
