TwinTurbo.NET: Nissan 300ZX forum - The gauge will not indicate a reading until the system has
Subject The gauge will not indicate a reading until the system has
Posted by SammybTT(TN) on November 05, 2015 at 7:00 PM
  This message has been viewed 273 times.
In Reply To boost leak test posted by aztec300z on November 05, 2015 at 03:49 PM
Message Been pressurized. General rule is to use no greater than 7 psi however that is dependent upon your setup. My experience is it takes a couple of minutes for the system to equalize to the applied Inlet pressure. I use an air blow nozzle to apply the inlet pressure and then release and listen for leaks if I suspect a leak. As Jzack mentions a photo or more information on your test procedure would be helpful. Good luck!
