TwinTurbo.NET: Nissan 300ZX forum - My Blush on it
Subject My Blush on it
Posted by Cjw3 on November 04, 2015 at 8:12 AM
  This message has been viewed 520 times.
In Reply To 740cc upgrade > now rough idle (long) posted by Maverick on November 03, 2015 at 10:09 PM
Message Cold the ECU will be open loop.. running rich.. Closed loop will be 'Normal' Mixture..
I think you might have an intake leak, causing a lean somewhere.. Likely in the Lower plenum area..
OR the idle mixture in the ECU programming is set too lean
Get some software to allow you to see O2 Sensor Voltage.. see where you are at at idle.. I've had to richen up my 3 NA's to get them to idle properly ( lean stumble ) and they now idle in O2 Sensor Feedback..
ECU Talk, or Conzult will allow you to do this.. Need an interface cable for both
Cj
