TwinTurbo.NET: Nissan 300ZX forum - With the engine removed?
Subject With the engine removed?
Posted by -Grimm- on November 03, 2015 at 9:59 AM
  This message has been viewed 262 times.
In Reply To Remove Crankshaft posted by FrozTTy on November 03, 2015 at 09:25 AM
Message I wouldn't say its a terribly hard job, just very time consuming, but I have worked on many cars and have all the tools and space so it may be easier for me.
In somewhat of the correct order:
-Engine out of car, transmission off
Rear of engine removal
-Flywheel/flexplate off
-Oil seal retainer off
Transmission brackets off
-Peripherals off (PS, Alt, pulleys, etc)
-Water pipes off
-Timing cover off
-Timing belt off
-Crank sprocket off
-Turbo drain pipes off
-Oil pan off
-Oil pump off
-Remove all connecting rod caps (youll have to put the crank bolt back in to rotate the crank for this) *Keep rod caps in the proper order so they go back in the same spots
-Main caps/girdle off
Crank out
Of course, make sure you loosen main bolts in small steps to avoid warping anything, same with connecting rod bolts
Im sure I missed some small things, but this will give you a general idea...
1992 300ZX NA 5 Sp (Dead)
1990 300ZX NA Auto 2+2 (Dead)
1990 300ZX TT 5 Sp (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2008 Honda Civic (DD)
1969 Chevy C10 (Toy)
1969 Chevelle (Toy)
