TwinTurbo.NET: Nissan 300ZX forum - Re: Get one of these...makes the job so much easier.
Subject Re: Get one of these...makes the job so much easier.
Posted by 95TTurboZX on November 03, 2015 at 8:25 AM
  This message has been viewed 305 times.
In Reply To Get one of these...makes the job so much easier. posted by jzack on November 02, 2015 at 08:52 PM
Message That's good for the non-Bose or if you replace the speakers also. I have the correct Metra adapter, I believe it is the 70-1764. In either case, there is still a wire on the adapter that corresponds with pin 6 "joint harness" of the factory vehicle connector. Metra identifies this as ground vs joint harness. The only other wire from the new head unit harness not hooked up is the chassis ground. So is the "joint harness" actually a ground that I need to hook up to the chassis ground? Thanks
