TwinTurbo.NET: Nissan 300ZX forum - Re: You are seeing wastegate boost pressure
Subject Re: You are seeing wastegate boost pressure
Posted by TurboTurtle (WaldorfMD) on October 25, 2015 at 10:26 PM
  This message has been viewed 315 times.
In Reply To You are seeing wastegate boost pressure posted by ttsmokin on October 25, 2015 at 09:52 PM
Message The vacuum setup looks crazy. I will take pics tomorrow. However it was only two wire off the ebc that were burned. So I simply cut out the bad section and rerouted it away from the manifold. Is the boost controller installation any different for a twin turbo setup? It may be that when it was serviced by a less than reputable mechanic. He may have moved around a few vacuum lines.
