TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: CAS is not in the center to set my timing at 15
MaxxAction
on October 25, 2015 at 7:39 PM
posted by JFRacing
on October 25, 2015 at 07:13 PM
That isn't enough to change anything significantly. As long as you are not maxed out one way or the other, it will be fine.
JFRacing
18:00:37 10/25/15
MaxxAction
19:02:05 10/25/15
JFRacing
19:13:43 10/25/15
Re: Re: Re: CAS is not in the center to set my timing at 15 -
MaxxAction
19:39:31 10/25/15
Re: Re: Re: Re: CAS is not in the center to set my timing at 15
JFRacing
20:38:21 10/25/15
Do you have +0.010" head gaskets? (n/m)
-Grimm-
10:26:49 10/26/15
Re: Do you have +0.010" head gaskets?
JFRacing
11:03:23 10/26/15
Your timing will be off by...
-Grimm-
15:07:17 10/26/15
Out of curiosity, how do you get those #?
ttsmokin
10:14:59 10/27/15
Do you have conzult or similar program?
ttsmokin
21:55:30 10/25/15
Re: Do you have conzult or similar program?
JFRacing
11:03:57 10/26/15
Inspect CAS splines and flat for wear (n/m)
ttsmokin
13:21:12 10/26/15
Coolspot
09:17:24 10/27/15
Flip the connector over and you'll get the right reading. (n/m)
Woody75 (Denver)
09:25:11 10/27/15
JFRacing
11:35:03 10/27/15
