TwinTurbo.NET: Nissan 300ZX forum - LIKELY corrosion ..
Subject LIKELY corrosion ..
Posted by Cjw3 on October 24, 2015 at 6:16 PM
  This message has been viewed 277 times.
In Reply To 5 year sit. new oil. cranks but wont start posted by ToneZ32 on October 24, 2015 at 05:53 PM
Message Pull the plugs and squirt a little oil down each one.. then put them back..
Use starting fluid in the Brake Booster Feed Line to the intake Manifold.. Have someone crank while you spray it in..
If you have spark, it will lite and run.. Like Krap for a bit till things seal up..
Cj
