TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Best size tires?
Subject Re: Re: Best size tires?
Posted by Danbarnett123 on October 23, 2015 at 1:01 AM
  This message has been viewed 266 times.
In Reply To Re: Best size tires? posted by crexxx on October 23, 2015 at 12:32 AM
Message 10" with +20 is well into "stance" territory.
With a roll/pull of fenders, the 225/40 has the right amount of stretch to make it work (not that it's safe).
Go on rimtuck and look at others setups.
I will be running 18x10 +30 with 255/35 on the rear. Basically the narrowest tire that major companies can recommend I.e. discount tire, tire rack. 18x9 +30 front, undecided on 225/40 or 235/40 or 245/35, trying to keep diameter matched with rear.
Twinturbo.net members are big fans of functionality not stance, you will get a lot of criticism for running those sizes.
Unless you have 450hp+, wheels wider than 8.5" will probably be slowing you down due to weight. Having said that, i have an NA with about 240hp and I think it looks badass so I'm going with wide wheels too.
