TwinTurbo.NET: Nissan 300ZX forum - You said the clutch pedal feels inconsistent, try bleeding
Subject You said the clutch pedal feels inconsistent, try bleeding
Posted by ttsmokin on October 22, 2015 at 10:14 PM
  This message has been viewed 297 times.
In Reply To 300zx experts HELP! Weird 4th gear issue posted by turbosiavr on October 21, 2015 at 11:30 PM
Message I would suggest bleeding the clutch system, make sure to bleed at the location up on the fender as well as the slave cylinder. Water in the fluid can cause issues. I would also suggest checking the adjustment on the clutch pedal as follows:
http://specialtyz.com/blog/?page_id=178
Also, the short section of rubber hose between the slave cylinder on the transmission and the hard line could be aged, allowing the rubber to expand. This is commonly replaced with a braided stainless steel line.
Slave cylinders usually leak when they go bad, look for fluid leaking from the plunger end of the slave cylinder.
