TwinTurbo.NET: Nissan 300ZX forum - Okay so i think I've got a gameplan
Subject Okay so i think I've got a gameplan
Posted by Z32CheekiBreeki on October 11, 2015 at 8:39 PM
  This message has been viewed 394 times.
In Reply To Re: You mean the NA drivetrain? posted by Cjw3 on October 11, 2015 at 04:55 PM
Message New turbo CHRAs $800
Gasket kit $240
Rod and main bearings $150
Piston rings $180
Then I think $500 is a fair amount to budget any machine shop work (heads)
Then just gonna reuse the water pump and Tbelt since they are brand new, and hopefully I'll be golden
Is a new oil pump necessary? I noticed the current TT would sit at about 15 psi warmed up on idle on a hot day. I think it might be worth the insurance
Now here another thing. I wanna make sure this doesn't happen again. I think I just ran into some bad luck, but I wanna make sure nothing I do can cause another failure
What are the causes of rod knock? I understand it is generally oil starvation, but where can that problem come from? If I make good oil pressure is it safe to assume that everything is properly lubricated? Or perhaps is there a clogged oil passage somewhere that caused this in the first place
