TwinTurbo.NET: Nissan 300ZX forum - Sounds as if an injector may be out? Could be just a
Subject Sounds as if an injector may be out? Could be just a
Posted by jzack on October 10, 2015 at 9:41 AM
  This message has been viewed 317 times.
In Reply To Re: Re: New Z owner need some help posted by leo90z-tt on October 09, 2015 at 07:46 PM
Message Connector corossion issue too? Do a power balance test. With engine idling at normal temp, unplug each coil pack and see if the idle gets worse(reconnect coil once done). When you get to the cylinder that sees no idle change that's the cylinder with an issue. This test helps to narrow down the issue. Report back and we'll tell you what to do next.
