TwinTurbo.NET: Nissan 300ZX forum - I had to replace mine due to similar intermittent ignition
SammybTT(TN)
on October 07, 2015 at 11:51 AM
CAS woes?
posted by RZturbo
on October 07, 2015 at 09:52 AM
fluctuation. Drive pin was not worn or corroded and the wiring and connections were ok. appeared to be an internal component failure.
CAS woes?
RZturbo
09:52:06 10/07/15
Re: CAS woes?
Joe@ZSpeedperformance
09:59:28 10/07/15
I'm more inclined to believe it's the CAS disc itself.
bartz32tt
10:03:49 10/07/15
I had to replace mine due to similar intermittent ignition -
SammybTT(TN)
11:51:32 10/07/15
You could try this:
ttsmokin
13:24:12 10/07/15
I just log another run
RZturbo
13:34:04 10/07/15
Re: I just log another run
MaxxAction
15:55:53 10/07/15
It fluctuates about 100rpm within 1/10 of a second
RZturbo
22:34:31 10/07/15
No, this is not normal.
OverZealous (CT)
19:28:34 10/07/15
Reference Link
OverZealous (CT)
20:51:54 10/08/15
I have gone through lengths explaining this problem to you..
kickerzx
02:01:32 10/08/15
^He has posted some pretty nifty graphs of this (n/m)
-Grimm-
09:33:16 10/08/15
To my surprise, the CAS teeth and cam drive pin both
RZturbo
00:42:13 10/09/15
Not going to work... I understand that it's graph time again
kickerzx
02:17:28 10/09/15
We shall see. If that doesn't work, I'll try AEM disk next. (n/m)
RZturbo
08:26:45 10/09/15
Mhm.... Graph time!
kickerzx
10:13:02 10/09/15
Norsk i huset! Nice post.
OverZealous (CT)
20:37:05 10/09/15
Javist. Norsk tvers igjennom. That S13 enginepicture...
kickerzx
00:33:41 10/10/15
Oh, that S13 one is a megasquirt log. The rest Vipec/Link. (n/m)
kickerzx
02:53:06 10/10/15
Re: Oh, that S13 one is a megasquirt log. The rest Vipec/Link.
OverZealous (CT)
18:18:56 10/10/15
