TwinTurbo.NET: Nissan 300ZX forum - CAS woes?
Subject CAS woes?
Posted by RZturbo on October 07, 2015 at 9:52 AM
  This message has been viewed 548 times.
Message I'm getting erratic RPM signal throughout the rpm band. This is throwing ignition and injector pulse all out of whack. I logged this graph.
Look at the green rpm graph where the vertical red line, it went from 7300rpm to 8300rpm in about 0.1 second. Is this something that is typically observed on Z32 OEM CAS. BTW, I'm using the Haltech to log this. I've found the CAS connector is be badly corroded. Is this something could be related to the dwell pin wearing out?
