TwinTurbo.NET: Nissan 300ZX forum - Can you measure the ID of the bush and OD of shifter hole?
Subject Can you measure the ID of the bush and OD of shifter hole?
Posted by ttsmokin on October 03, 2015 at 5:24 PM
  This message has been viewed 379 times.
In Reply To shifter bushings posted by lbw46 on October 03, 2015 at 03:49 PM
Message There is supposed to be a press fit for brass bushings (aka oilites). Something that small would probably be 0.001" of interference.
Hammer and wood block is not the right way. You need an arbor press or a hydraulic press. If they go in crooked you will crack the brass bushing.
