TwinTurbo.NET: Nissan 300ZX forum - A few comments:
Subject A few comments:
Posted by ttsmokin on September 30, 2015 at 8:29 PM
  This message has been viewed 408 times.
In Reply To talk to a machinist about the crank posted by wickdGSXR on September 30, 2015 at 07:07 PM
Message -Don't try to fix a scored/damaged crankshaft. Get a good used one that runs true in a set of v-blocks. The factory crankshaft is nitrided, if you had the crankshaft ground you have get the crank re-nitrided. Another reason for getting a good used crank.
-90mm is a big overbore without first checking the block for enough thickness. See here: http://www.motoiq.com/MagazineArticles/ID/1508/Engine-Tech-Building-the-Nissan-VG30DETT-part-1.aspx
-N/A oil squirters are for aftermarket forged pistons
-I wouldn't suggest using re-bar to bang out the casting. I would suggest using a dremel like tool to remove the extra material.
