TwinTurbo.NET: Nissan 300ZX forum - Yes all is posable
Subject Yes all is posable
Posted by Cjw3 on September 29, 2015 at 7:53 AM
  This message has been viewed 444 times.
In Reply To Some questions about engines. posted by Placuch on September 28, 2015 at 11:03 PM
Message The 96 engine is compatible with OBD1 wire harness EXCEPT the TPS and Water Temp Sensor
A Dissembled Old motor is worth no more than $200..
What you will have there is a '95 motor with a different TPS/Left T Body, and NO VTC.. VTC will jump in with NEW intake Cams, and VTC Sols..
Any motor you have to beat the pistons out of is a junker.. and it will have to be bored.. so it makes no difference if the pistons are broken, they can't be used..
Get yourself one more motor and you might be able to make one run..
Cj
I stuffed a running '96Na motor in my NA '90 Dailt Driver.. no issued except as noted..
