TwinTurbo.NET: Nissan 300ZX forum - Problem solved
Subject Problem solved
Posted by Diplomat1 on September 26, 2015 at 3:42 PM
  This message has been viewed 421 times.
In Reply To I would start simple and check fuel pressure posted by SammybTT(TN) on September 26, 2015 at 09:44 AM
Message It was a bad connector to the number 1 cylinder fuel injector. It started to misfire at idle so i did the power test and found it was that cylinder and saw the corrosion on a wire. New connector runs like a champ thanks
