TwinTurbo.NET: Nissan 300ZX forum - Agree with CmyZ, pump is probably a remanufactured
Subject Agree with CmyZ, pump is probably a remanufactured
Posted by ttz'in (norcal) on September 22, 2015 at 11:11 AM
  This message has been viewed 508 times.
In Reply To Re: Bad bearing overtigthening it can be the problem. If posted by Diplomat1 on September 22, 2015 at 09:55 AM
Message unit. OEM pumps seem to work best.
Over flow hose problem was due to belt coming off and pump not circulating coolant thru radiator. Pressure then went to high and found the easiest way out.
