TwinTurbo.NET: Nissan 300ZX forum - I don't understand
Subject I don't understand
Posted by wickdGSXR on September 21, 2015 at 5:57 PM
  This message has been viewed 411 times.
In Reply To 96tt breather mod and E85 question posted by Lone Z'er(CO) on September 20, 2015 at 01:29 PM
Message I personally don't like pulling the motor out more times than I have to. Did you do a compression test first? if your rings/valves are bad then any mods are pointless.
Assuming your bearings/rings/valves are good, then you want to do whatever mods must be done while the engine is out. Installing a Walbro, going e85 lines, etc can be done later.
I went 740cc injectors then changed my mind. Not sure they can supply enough e85 for a fully built Z. Replacing parts and dynotuning over and over again cost $$$.
