TwinTurbo.NET: Nissan 300ZX forum - or disable it completely...
Subject or disable it completely...
Posted by zromtech on September 13, 2015 at 6:15 PM
  This message has been viewed 353 times.
In Reply To I would replace the sensor either way posted by -Grimm- on September 13, 2015 at 02:31 PM
Message Fuel temp is only used by the PRVR system, which is only active for 30 seconds on hot starts. You can either completely remove PRVR, or force it to use coolant temperature instead of fuel temperature on startup. You'll also need to reprogram the ECU to disable the code 42 if you do unplug the sensor. I deleted the PRVR system in my car and now use the fuel-temp circuit as a clutch switch input to the ECU for no-lift shifting.
