TwinTurbo.NET: Nissan 300ZX forum - Re: Your gain setting is way too high.
twan
on September 10, 2015 at 5:42 PM
posted by Zebszx
on September 07, 2015 at 09:49 AM
Thanks for that I am running jwt sport 500 and was told that 19lbs was not bad for turbos and or engine I have every other upgrade minus the internal engine work so if running 93 what would you suggest as far as boost levels vs running 105
Boost Controller issues and power steering pump belt
twan
22:56:06 09/05/15
What fuel are you using? (n/m)
Tanley (ATL)
07:29:23 09/06/15
Re: What fuel are you using?
twan
09:01:18 09/06/15
How much deflection in the belt if you press it
ttz'in (norcal)
13:48:32 09/06/15
Re: How much deflection in the belt if you press it
twan
20:11:41 09/06/15
Re: Boost Controller issues and power steering pump belt
twan
08:25:41 09/07/15
First, read this.
Tanley (ATL)
09:47:50 09/07/15
Zebszx
09:49:58 09/07/15
Re: Your gain setting is way too high. -
twan
17:42:46 09/10/15
for reference here are my settings, stock turbo, 16.5 psi
itsa300zx
12:14:50 09/08/15
Re: for reference here are my settings, stock turbo, 16.5 psi
twan
17:45:02 09/10/15
