TwinTurbo.NET: Nissan 300ZX forum - The TT and NA use different PCV's
Subject The TT and NA use different PCV's
Posted by Goldchocobo on September 10, 2015 at 10:22 AM
  This message has been viewed 310 times.
In Reply To Theyre fairly new posted by Z32CheekiBreeki on September 10, 2015 at 09:03 AM
Message Sounds like you are getting intermittent blowby, which makes sense. Definitely replace them before you start taking the engine apart.
While you are doing that, clean out your pcv hoses and check your intakes for excess oil. Clean out the oil as best you can. Also, check your oil levels. Too much oil will flood the system and exhibit the problems you are having now. I would know, I had this very issue.
