TwinTurbo.NET: Nissan 300ZX forum - The o-rings felt like they set perfectly
Subject The o-rings felt like they set perfectly
Posted by platinumist on September 07, 2015 at 11:44 PM
  This message has been viewed 272 times.
In Reply To Injectors firing with CAS rotation does not test o-rings posted by ttsmokin on September 07, 2015 at 11:23 PM
Message but I will keep that as a possibility and check the plugs. Yes first time, after further research I should have counted the teeth, but everything was perfectly lined up and I rotated the assembly multiple times. If the belt jumped, would that cause a rich mixture? Anything else I can check before I start tearing it down again?
