TwinTurbo.NET: Nissan 300ZX forum - Injectors firing with CAS rotation does not test o-rings
Subject Injectors firing with CAS rotation does not test o-rings
Posted by ttsmokin on September 07, 2015 at 11:23 PM
  This message has been viewed 345 times.
In Reply To Re: Possible you pinched an injector o-ring on install posted by platinumist on September 07, 2015 at 10:52 PM
Message If you are smelling a very rich mixture, it's highly likely an o-ring is pinched. I would pull the spark plugs to see if they are soaked in gas.
Was this your first time setting the timing belt?
