TwinTurbo.NET: Nissan 300ZX forum - Your gain setting is way too high.
Subject Your gain setting is way too high.
Posted by Zebszx on September 07, 2015 at 9:49 AM
  This message has been viewed 275 times.
In Reply To Re: Boost Controller issues and power steering pump belt posted by twan on September 07, 2015 at 08:25 AM
Message When I installed my controller I was advised to set gain at 8-15. My Set is at 75% to achieve 15.5 boost, but I'm at 7400 feet elevation. Set would be lower to achieve same boost at 2000 feet.
Double check your hose connections at solenoid. If they are reversed you'll see it boost, then fall off to whatever your wastegate actuators are rated at.
Have you checked for boost leaks? Sometimes leaks will occur at higher pressures only.
Also make sure your limit settings are set properly and aren't interfering with your desired boost level.
