TwinTurbo.NET: Nissan 300ZX forum - Could just put some air pressure in a large bottle >>
Subject Could just put some air pressure in a large bottle >>
Posted by ZUL8TR on September 07, 2015 at 5:06 AM
  This message has been viewed 251 times.
In Reply To Z32 clutch bleed posted by DRED on September 01, 2015 at 11:43 PM
Message of brake fluid that is attached to the slave fill valve. Doesn't take much pressure, 4 psi will push the brake fluid up about 9 +ft. more than enough to reach the top bleed point. There are several was to simply pressurize the brake fluid bottle even with a bicycle pump.
Your closed system is a good approach to get around the PITA standard usual clutch bleed method.
ZUL8TR in Orlando,FL
