TwinTurbo.NET: Nissan 300ZX forum - Z32 clutch bleed
Subject Z32 clutch bleed
Posted by DRED on September 01, 2015 at 11:43 PM
  This message has been viewed 336 times.
Message To those of you who have tried and tried to get the air out of the clutch to slave system, the bleed valve is located on the top of the right fender right there in plain sight. The bleed valve on the slave can and should be used to fill the system not bleed it, air rises. New master/ new slave. All lines empty of fluid. open the bleed valve on top and put a 3/16" hose on it to the master cylinder reservoir below where you want the fluid to be. Put another hose connected to the Slave bleed valve. connect the slave line to a large syringe (avail at Walmart $15.99)full of fluid. You will have to add about 2.5 of these to completely fill the system from the bottom up. close the valves and try the clutch a few times. If there is still a little air in the system it is now at the top and easily removed from the fender bleed valve. I just did my system this way, works perfect. P.S. you need about 15 feet of 3/16" ID vinyl hose to make a closed system.
DrEd
