| Subject |
Idles well, does not react to throttle |
| Posted by |
mboston on August 30, 2015 at 10:54 PM |
This message has been viewed 406 times. |
| Message |
Hello, Been doing some engine work, replaced a rotten efi harness and shot turbos. Put the car back together, fired it up hesitates to start at first, maybe 5 cranks or so. After that it does idle well, around 900 to a thousand rpm, exhaust flow is smooth. But when the throttle is opened wide open, it will hesitate its way up to around 1800 rpm or so then drops to idle even with the throttle wide open. How ever it will only respond like this is you open the throttle quickly, if not it just does not respond at all. Suggestions? Thanks.
| Follow Ups |
- Idles well, does not react to throttle - mboston
22:54:35 08/30/15
Post a Followup |
