TwinTurbo.NET: Nissan 300ZX forum - Re: Given there is already a hose fuel leak...you'll need to be
Subject Re: Given there is already a hose fuel leak...you'll need to be
Posted by lvdisturbed1 on August 30, 2015 at 4:08 PM
  This message has been viewed 379 times.
In Reply To Given there is already a hose fuel leak...you'll need to be posted by jzack on August 30, 2015 at 10:10 AM
Message I think I found the issue. Lower right hose (not sure if send or return) on fuel pump assembly is "T" to hose goint to the front with one end capped off. The cap is cracked to hell. I'll post a few pics, never posted pics here so I hope I get them right...
Cutting isn't the cleanest, but I had a support bar in the way making proper angle difficult, plus some coating (heat shielding?) gunking up the cut.
