TwinTurbo.NET: Nissan 300ZX forum - Yes on 1st Q. Unplugging the brake booster hose >>
ZUL8TR
on August 26, 2015 at 3:14 PM
Re: Also vacuum test will reveal other leaks. Check the >>>
posted by monkeymantn
on August 26, 2015 at 12:05 PM
will probably create too big of a vacuum leak and the engine will stall.
What is the cigar test?
Do the vacuum gage test, the gages are not expensive and the results are very informative.
ZUL8TR in Orlando,FL
Hunting idle, hesitation....MAF???
monkeymantn
21:33:56 08/22/15
Did the TPS get messed with during this repair? I'm
jzack
08:06:42 08/23/15
See this recent posting too...
jzack
08:08:55 08/23/15
Here is another option
Cjw3
09:13:32 08/23/15
Re: Hunting idle, hesitation....MAF???
monkeymantn
21:17:15 08/23/15
How did you clean the MAS ? The hot wire sensor >>>
ZUL8TR
05:48:39 08/24/15
Re: How did you clean the MAS ? The hot wire sensor >>>
monkeymantn
09:05:10 08/26/15
EGR is a good possibility, it could be sticking? >>>
ZUL8TR
10:35:12 08/26/15
ZUL8TR
10:39:02 08/26/15
monkeymantn
12:05:31 08/26/15
Yes on 1st Q. Unplugging the brake booster hose >> -
ZUL8TR
15:14:16 08/26/15
Re: Yes on 1st Q. Unplugging the brake booster hose >>
monkeymantn
21:08:03 08/26/15
For smoke to leave it must have pressure greater >>
ZUL8TR
04:45:20 08/27/15
