TwinTurbo.NET: Nissan 300ZX forum - Also vacuum test will reveal other leaks. Check the >>>
ZUL8TR
on August 26, 2015 at 10:39 AM
EGR is a good possibility, it could be sticking? >>>
posted by ZUL8TR
on August 26, 2015 at 10:35 AM
1" diameter (+/-) S shaped hose that goes to the idle control
it might be cracked at the connections. I had to replace mine when I replaced all 6 injectors.
ZUL8TR in Orlando,FL
Hunting idle, hesitation....MAF???
monkeymantn
21:33:56 08/22/15
Did the TPS get messed with during this repair? I'm
jzack
08:06:42 08/23/15
See this recent posting too...
jzack
08:08:55 08/23/15
Here is another option
Cjw3
09:13:32 08/23/15
Re: Hunting idle, hesitation....MAF???
monkeymantn
21:17:15 08/23/15
How did you clean the MAS ? The hot wire sensor >>>
ZUL8TR
05:48:39 08/24/15
Re: How did you clean the MAS ? The hot wire sensor >>>
monkeymantn
09:05:10 08/26/15
ZUL8TR
10:35:12 08/26/15
Also vacuum test will reveal other leaks. Check the >>> -
ZUL8TR
10:39:02 08/26/15
Re: Also vacuum test will reveal other leaks. Check the >>>
monkeymantn
12:05:31 08/26/15
Yes on 1st Q. Unplugging the brake booster hose >>
ZUL8TR
15:14:16 08/26/15
Re: Yes on 1st Q. Unplugging the brake booster hose >>
monkeymantn
21:08:03 08/26/15
For smoke to leave it must have pressure greater >>
ZUL8TR
04:45:20 08/27/15
